joltman
I am brand new to the forum. I've inherited a 1993 Nighthawk 750 from the father-in-law (FIL). I've had it since May 2012. It's been fun driving to work and back. I have had some issues with the turn signal switch not always turning on, and sometimes it hasn't turned off when I pressed "inwards". It used to take a firm push inwards to turn it off.
Last summer, it didn't get a lot of use. I had it in a "garage" (more a building with holes) and that seemed to keep it mostly protected. I was forced to tear down that garage when I was selling my house. So the bike sat outside for over a month. When I finally got back on it, I was heading to the gas station. I turned on my blinker and then all the lights stopped working on the bike. It then just stopped. I found that the fuse for the lights/neutral was blown (15A). I replaced the fuse with a new 15A. Luckily, I wasn't too far from home, so the wife went to get my Tahoe to jump the bike. I had the Tahoe off and on (which I just learned is bad). The bike would start while jumpered to the 'Hoe. When the bike was running, I tried the turn signal again. Another blown fuse. Eventually, the bike let out an enormous POP! It wouldn't start after that. I had to push the bike back to home. When I got there, I found that the battery was low on water. I went to fill it up, and water was leaking from a crack in the side of the battery. That is most likely what caused the pop.
Fast forward to today. Wife and I have moved from IL to Denver and brought our bikes with us. Obviously, mine isn't running. Today I went to Interstate Battery to pickup a new battery (AGM). I brought it home and popped it in the bike with a brand new 15A fuse. Guess what!? I was able to use the left blinker no problem (heard the blinker clicking noise as well). When I tried the right blinker, the blinking noise was faster and the right lights weren't blinking. However, the brake and headlights seemed to dim to the sound of the blinker clicking noise. Then the fuse blew. Crap.
Luckily, the FIL gave me a Clymer Service/Repair/Maintenance manual for this bike! I was checking the electrical troubleshooting area. The instructions told me to take off the neg lead to the battery and take out the bad fuse (which doesn't really matter). Then, to take out the headlight and trace the wire bundle from the turn signal switch on the left handle to the headlight housing. It told me to test the continuity between 4 pairs of wires using a multimeter. Below are my results:
* This went up to over 8 Ohms on a few occasions
This table shows the connections I made from the switch side of the harness in the headlight assembly to the actual front turn signal lights. I used my multimeter and the ohms are shown in the table. I have no idea if this is even normal. How do I know what I should be getting? The book just tells me this:
The dashes indicate where there should be "continuity". I took that to mean a "closed circuit". So I had one lead of my multimeter on Gray, the other on Skyblue. Then I hit the right turn switch, then off, then left turn switch. I did that several times too. The switch wasn't smooth to move either. It would also take maybe a push or two to turn off.
Can anyone help me? I hope I've provided good information. Thanks!
| Switch Harness-Lights | Right Switch | Left Switch | Switch Off | |
| R | Gray-SkyBlue | .5 Ohm | 2.3 Ohms | Infinity |
| R | Black/Brown-Skyblue/White | 5.7-5.1 Ohms | .9-.2 Ohms | .6 Ohms |
| L | Gray-Orange | 2.8-2.1 Ohms | .7-.3 Ohms | Infinity |
| L | Black/Brown-Orange/White | .5 Ohms | 5.8-5.3 Ohms * | 1-.7 Ohms |
| Right | Gray-Skyblue | Black/Brown-Skyblue/White |
| None/Off | Black/Brown-Orange/White-Skyblue/White | |
| Left | Gray-Orange | Black/Brown-Orange/White |
