Mag wheels for a 1975 CB750F
stephen
Illinois
Hi everyone, I'm new here. I recently got a 1975 CB750F, which has spoked wheels with disc brakes on both ends. I had a nightmare of a time replacing the 35-year-old tires and tubes that were on it over the weekend, and don't really want to deal with that again next time around, and I also found a bent spoke on the rear. Does anyone know of a set of tubeless mag wheels that would work as direct replacements? It seems the Comstar front wheel is no problem, but I think the rear disc brake on the F may be an issue.
Thanks!
Check out the zip tie method on Brick House Builds youtube I used the method anf it works a treat plenty of soapy water and went straight on, didn't even need my tyre levers ( thats tire irons to you) ;-)
Know what you mean about the rear disc, apart from pads and pistons every other parts are made of unobtainium, I'm still trying to find the spring clip which fits between the pad pins.
Loki
