Hello, 1.5/2, to start... Then you normally open between 1.5 and 3 turns. No more than that. If you need to open more, be sure there's a clogged duct (try a larger jet on the low-end jet, it might be worth it). If the jet screw is on your carburetors on the intake side, the more you open, the more air the mixture will have at idle.
If it's on the air side, the more you open, the more air the mixture will have.
The jets only work at idle. If you fail above 1,500 rpm, the issue lies elsewhere.
The carburetors are over 40 years old, it won't be easy (clogged ducts, enlarged sprinkler tips, etc.). Trial and error, my dear friend. I've been here for a year, but I have the VB42s.
So let's keep experimenting together. I'll be active on this forum.
Good luck with it and have a good trip... when you're on the road, haha.
Translated with Google Translate
