K4 Oil Leak
Clute73
21
Pearland, TX 77581, USA
Seem to have oil leak from the area shown in photos. I thinks this is a cable that is part of the oil pressure switch not sure. Is this a seal or is there an o ring underneath the screw. I have looked in the Honda parts diagram but cannot locate any info. Thanks for nay info.
That is the neutral sender and detent for the transmission. They either leak from the big oring that seals it to the case or the sensor leaks out of the end in which case you have to replace it. They are still available from Honda.
I am replacing sender unit, could you please advise on removing old unit. Is there some specialty tool to remove.
no you just take the screw off and the wire off and take the bolt out and the retainer and it pulls out, might be hard to pull out if the oring is hard.
Thank you, got it
