YES post #20.
I almost asked the same 'why change the needle' question like 5 times. They RARELY cause trouble unless shimmed then not being loose they wear like lightning. Even the shimming can be done if careful, but the needle MUST be able to still wobble loose, it's what allows it to center to the jet and then zero wear. Just like with the labyrinth slides the DOHC uses with no rubber, you have enough flow there so that the flow itself guarantees that the sides stay centered. The sides in normal use then never touch at all.
I too have changed less than 5 needles on so many carbs rebuilt I cannot say, they simply do not wear except possible heavy dirtbike use and vibration like a big single 2 stroke makes. Of course possible corrosion due to being in a humid atmosphere could be an issue but I pretty much DON'T change them ever. Reason being, they worked good and you don't f-ck with that. And NEVER take sandpaper to them! I'll do that to every other part on a bike but NOT needles or slide tops, it's death!
Rule #1 is you NEVER change all parts simply because they are 'in the kit'.........................................ONLY what's needed and a good sum up there.
Man, if you knew all the posts I've seen after somebody changed needles and then bad result followed in short order.................can't stress it enough.
