P pelikan909 CB750 Member Messages 7 Reaction score 0 Points 1 Location reno Feb 27, 2022 #1 is it better to a carb with the fuel pump, or just disregard this plus connect the tank directly to the carb
dirtdigger Moderator Staff member Top Contributor Messages 3,779 Reaction score 280 Points 83 Location US Feb 27, 2022 #2 Sohc never had a fuel pump so from tank to carbs direct is fine.
P pelikan909 CB750 Member Messages 7 Reaction score 0 Points 1 Location reno Mar 10, 2022 #3 If a pump is present from a carb I bought, should I keep it of toss? any disadvantage in keeping
dirtdigger Moderator Staff member Top Contributor Messages 3,779 Reaction score 280 Points 83 Location US Mar 10, 2022 #4 No pump needed. Send a picture of what you got.
P pelikan909 CB750 Member Messages 7 Reaction score 0 Points 1 Location reno Mar 11, 2022 #5 the lower round part hooked to the fuel line, I think is a pump no? Attachments IMG_1603.jpg 46.5 KB · Views: 131
dirtdigger Moderator Staff member Top Contributor Messages 3,779 Reaction score 280 Points 83 Location US Mar 11, 2022 #6 no thats a vacuum operated fuel shutoff valve.
P pelikan909 CB750 Member Messages 7 Reaction score 0 Points 1 Location reno Mar 11, 2022 #7 should I keep it?, I have seen some removing this
dirtdigger Moderator Staff member Top Contributor Messages 3,779 Reaction score 280 Points 83 Location US Mar 11, 2022 #8 No need as long as you use the valve on the tank you will be fine.
P pelikan909 CB750 Member Messages 7 Reaction score 0 Points 1 Location reno Mar 11, 2022 #9 thank so much, helping this beginner!!! All good to you
