Installing carbs
Woodbutch
9
Florida
I have a 1981 750 custom and am unable to get carbs back on intake boots. Gave up with replacement cheap boots because they are all the same size . I have used grease, wd40 and trying to tap on with rubber mallet but unable to get carbs back on boots
Just rebuilt mine over the winter in my shed (new Hampshire pretty cold but my idea when I was at the end of my rope was to I took a ratchet strap wrapped around the frame in front of exhaust pipes around the entire engine and the choke intakes. As you ratchet tighter one click at a time I rocked the carb bank
Up and down .I know it is not conventional but it worked for me. After they were seated I installed the boot clamps . I started the engine and sprayed starting fluid and no leaks, good luck
