Hello, everybody. New to the group.
I have a question about carb tuning.
I'm working on my 1973 K4, which ive been working on returning to the road after the previous owner parked it in his basement in 2007.
I have disassembled, cleaned and reassembled the carbs. I'm using OEM brass. I have bench synced using the 1/8" drill bit method (from airbox side), and set the air idle screws at a turn and a quarter. I'm going to vacuum sync next.
The question I have is: how/when will I know that my idle air screws need adjustment? Should I vacuum sync first? What are the symptoms i'm looking for if I need an idle air screw adjustment? Currently the motor runs decent but exhaust smells a bit gassy, if that makes sense. Any input is appreciated.
Thank you.
Thank you.
