Help with wiring harness
xmoweryx
Midwest
Long story short I'm working on a 76' cb750 chopper. There was a short in the make shift wiring harness. So instead of trying to track that all down I've gotten a new factory spec wiring harness for a 76 k6.
The wiring on bike only has AC gen plug in and maybe one other. And I've went through and labeled wires on new harness to verify color codes
The bike is a stripped down version so the wiring need is mostly just to make engine run
The only other wiring I need to figure out is Headlight dim and high
Front brake switch
Rear brake switch
And rear tail light
I need to figure out how to tie that stuff into ignition switch. I do have a toggle switch for high and low beams. Along with a dedicated starter button. These a long with ignition switch are mounted in a box behind carbs under seat area.
Ive been looking through color diagrams trying to figure out best course of action but it's making me cross eyed. What I need is something to tell me to take wires coming from which part and where to tie it into ignition switch poles, starter switch, and toggle switch.
