Headlight out
elteeron
Phoenix
I have an 81 CB 750C, and am the original and only owner.
My issue now is that the headlight will not come on when turning the ignition on. This has happened before, and recently when starting the bike, after sitting all winter, the light came on after it was running about 10 minutes. The next day, it would not come on. That's still the case. I did change bulbs to no avail. With a test light, I get no power at the headlight plug. All other lights work and the fuse is good. Any thoughts?
Look around the starter button area, the button normally switches the light off when the starter goes up in operation, if that switching is messed up in the switch it can do that. Somebody else here recently had the same issue and that was it. The light normally goes off to allow max power to the starter, then releasing the button lets it come back on. Normally anyway.
