G Gerald CB750 Member Messages 9 Reaction score 1 Points 3 Location Japan Jan 8, 2021 #1 Have a 1975 cb750 with a slight head gasket seep of oil any suggestions thanks
dirtdigger Moderator Staff member Top Contributor Messages 4,100 Reaction score 440 Points 83 Location US Jan 8, 2021 #2 If it is the head gasket it will need to be replaced. If it is oily mostly up front just a little higher then the head gasket then it is the rubber nickle sized seals under the cam towers..Either way the engine has to be pulled to do the work.
