Gear shift oil seal
stevew2878
Washington
I recently had this (#35) oil seal completely blowout causing major oil leak. I ordered a new seal and and installed it. I went out for a 10 minute ride and had blown the new seal. I have another seal in order but before I install it I wanted to ask if there’s anything else I should be looking into? High oil pressure? Failing oil pump? Clogged oil tubes? When I installed the new seal I cleaned the area very well and installed the new seal in with the use of a similar diameter socket. I didn’t use any kind of RTV sealant or grease behind the seal. It seemed to go on just fine. Any advise would be helpful. Thanks
