I have removed pods airfilters and put a original airfilter box on, and changed the main jets.
First i thought that the main jets was size 120 from original, and the bike was running fine from idle to 5000 rpm (3-4-5 gear) and then it would not take the throttle unless I was going full throttle in all the gears up.
Then I find out of that my carbs was running with main jet size 105 from original. Then I mounted them.
Now the problem is when I give it full throttle from idle it will Stuttering up to 2500rpm and then runs fine. No problems at 5000 rpm at all.
info:
Honda 750 k2 with original airfilter,
original exhaust. Without “db killer”
Carbs 657B.
Synchronization of carbs done.
Air leak testet with start spray.
Carbs has been jetblastet and cleaned.
info:
Carbs 657B.
