mnvkngs65
Rehabbing my newly acquired 1973 CB 750. Ordered a new front brake master cylinder rebuild kit for a 73 and the piston is too narrow.
I believe the master cylinder on the bike is from a Goldwing based on the shape of the front of the brake lever? (the front brake was converted to 2 discs at some point - not sure if that is why the master cylinder was changed)?
The piston I need to replace is approximately 18mm wide at the center and approximately 49mm long. I can't find where to order a rebuild kit based on the piston size.
Any help would be appreciated.
Thanks!
Thanks!
