Exhaust pipes are un evenly hot
sirlordsir
So Cal
Just got a bike, fired it up and noticed that the left center header is not as hot upon warm up as the other three. I'm guessing a carb adjustment is in order? A familiar symptom to anyone?
it's a 1980 K
Could be carb adjust. Is it just a little cooler or cold? Is it an obvious miss on that cylinder or does it seem to run good? Idling does it occasionally pop in the exhaust? If it does a lot of times it is too lean in that cylinder. Carbs, ignition, compression, valve adjust can all affect how well a cylinder is firing. Checked how the spark plug looks? Check over the basics first, if it has been sitting for a long time the carbs are suspect in being gummed up and need a good clean and sync.
If you rev it up a little bit and hold it there for like 20 seconds, does it start to get hot? Having it almost cold at idle means it's not firing on that cylinder at that rpm. It could be a dirty carb or needing a carb sync.
Fouled plug...switch your plugs around from one cylinder that you know is good...if that doesn't work do a compression test(140 or better)
