AlphaJay
Hi, my name is Jay Sanford. Over the years, I've gotten a plethora of information from this site. Now I need some advice and this is my first time posting.
Skip ahead to “Where I'm at with it now.” to save time..
A few years ago, I inherited a ‘79 750F (basket case). There was a spare engine with it, and neither was well maintained. But it had new tires, so I couldn't let those go to waste. I utilized the better parts of the 2 engines to make one decent, ride able one. Bought new rings, bearings, seals, chain, and cables. Did the valves, and rebuilt carbs. I finally got it running in July of this year.
I only put eight or ten miles on it while trying to get it running properly. I had no leaks. I had a little difficulty getting it to idle properly, but it actually ran good. But I noticed some engine noise and it bothered me. Thinking I screwed up the valves, I took off the valve cover and discovered one of the middle exhaust Cam hold down bolts was broken. When trying to drill it out and remove it the bolt extractor broke. Rather than take it to a machine shop (due to finances), I decided to change the head to the one from the other engine, which was already all cleaned up. I re-lapped the valves, and put in new valve seals. And as I was putting the head on, I (so gracefully) dropped a head washer into the engine. They're copper so non-magnetic. I couldn't find it. Even upside down shaking it it didn't come out. So that left me no choice but to split the cases. I did finally find the washer in there, but I also found a bigger issue.
I saw a lot of bearing surface damage. Then I found a large chunk of metal that broke off of the front middle part of the lower engine case. I’m not sure, but I think it might be where the front cam chain tensioner anchors at the very front of the engine. I looked at my spare engine cases and the same piece was broken off of that one. But it was worse. It left a hole through the case.
I’m attaching a picture with the piece that broke circled in blue.
The case piece actually fits back almost perfectly when I'm holding it with my finger, of course. From my old days racing MX, I always thought that you can't really weld that kind of metal. I’ll go talk to a welding shop and see what they think, but I don’t want to have this happen again.
Depending on what you guys say, I may have to buy some used cases. There's a number of them available on eBay at the moment. What Engine years cases can I use, or not use?
From what I can see in some pictures, there seems to be a bit of a difference in the ‘80 - ‘82 cases. It looks like they redesigned it. If I use one of those later years will all my ‘79 parts fit? That's really my main question. I appreciate any help, tips, or recommendations.
Thanks in advance for your help.
- Jay
