Do compression test make sure you dont have low compression. Did you check if it had spark? Did you try to spray some carb clean in the carbs with running see if it helps?
Did a compression test a while ago, it seemed to be good.
i checked valve clearances and all were in tolerance but i may check again.
I put on new coils, and have them routed correctly.
I have brand new tuned carbs on this thing, mikuni vm34. 2 of them instead of 4.
The 2 each have a split manifold, 1 carb splits into 1 and 2 and the other into 3 and 4.
Also, the spark plug wires are 1,4 and 2,3....
So why is 2 and 4 not running?
The adjacent cylinders are running with the same carbs and the coil is firing for both as cyl 2 is on a diff coil than 4
But 1 and 3 are firing off fine.
They are on seperate carbs and seperate coils.
There is a electronic ignition module instead of points but i dont know how it works.
I did adjust the timing were the marks are between the notch when the light flashes. It seemed to start easier and all that.
Could the electronic ignition be faulty?
Really banging my head against a wall here.
