Webike Japan
The moment this billet swingarm pivot assembly for the Honda CB900F hit the bench, I ended up tearing into a stock setup just to see where the differences really are.
The OEM pivot hardware does its job. Honda designed it for durability and long service life. But once you start pushing these older chassis harder, especially with modern suspension, you begin to notice where wear and compliance creep in. It’s not one weak link, just small amounts of movement adding up through the pivot and swingarm under load.
This billet setup is machined from 7075-T6 aluminum, and the main difference is consistency. The tolerances on the pivot surfaces and spacers are tight, so everything lines up cleanly without having to chase play or compensate for wear. You’re not eliminating all movement, but you are taking a lot of variability out of the system.
The design here also shifts how loads are handled across the pivot. Instead of relying purely on aging needle bearings and collars, the upgraded hardware spreads load more evenly and gives a more controlled feel through the rear suspension. It’s less about being “ultra rigid” and more about being predictable when the bike is driven hard.
What stands out on the bike is how the rear end behaves under throttle. Corner exits feel more planted, and the transition from load to unload is smoother, especially on uneven pavement. It doesn’t transform the chassis on its own, but it tightens things up in a way you can actually use when dialing in suspension.
Curious how others are setting things up. When you firm up the swingarm pivot like this, are you sticking with standard chain slack specs based on geometry, or making small adjustments to suit a more controlled rear end feel?
https://japan.webike.net/moto_news/.../?utm_forum&utm_medium=388&utm_campaign=46114
