BillinSC
So, I get the importance of this measurement and setting the float height properly. My question is, which surface do you measure from as your zero point/reference? Is it outer most lip on the carb or the surface where the float bowl gasket rests (gasket removed for the measurement). There is also a small slightly raised area just inboard of the gasket sealing surface on my KEIHIN carbs. The gauges I've seen listed on line seem to take the measurement from the out lip of the carb and service manual isn't very clear. I know how to read verniers and dont really want to buy a specific gage if not necessary. Just looking for some insight on the correct surface to measure from. Thanks in advance
