clear coat on aluminum
They clearcoat SOME things but not all, any on engine are a special high-temp paint.
I had no trouble removing it with acetone if you let parts sit in it. I'd be careful with that water based stripper, I've ruined parts using it as ethanol is often used to make it miscible, then it phase separates to ruin the parts in as little as 24 hours if you let them sit thinking you are making things better. And, as noted, it doesn't even strip paint that well.
