prospector
Fit a new front sprocket today as one fitted was worn on the outside edge and decided to check alignment with a little laser pointer thing I had by clamping it to the rear sprocket and aiming at the front and it appears the chain adjusters are a full mark out on the lefthand side.
No movement in swing arm so appears reason for wear on sprocket.
