CB750K DOHC SPARK
JohnT
38
St George
Can anyone recommend a quality after-market ignition coil?
I believe I have a faulty one, and the next option is swapping out to check, but genuine are very pricey, but I've also heard that some after market are not good quality?
I would prefer the genuine look if possible and a full set with leads would also be worth considering.
Has anyone had experience with the Hendler brand?
Thanks
I use the next generation of Honda dual output coils. The ones marked MP08, they have a very good reputation. Many different models used this coil. 6 cylinder GoldWings used three. I've bought them on ebay for as little as $10 each. I use silicone 7mm, solid core, wire from NAPA, nice dark blue. On the CB's the stock brackets can be used and one hole drilled in frame web with bolt and nut because these coils are shorter. Same look as stock when mounted. No wiring changes.
