Can't remove cylinder head
LuckyPapa
9
northeastern us
I could use suggestions for removing the cylinder head from my CB750. The engine has been removed from the bike and all the bolts and fasteners have been removed.
Thank you for any assistance.
There are some "hidden" bolts, make sure that all the bolts are out first.
If all the bolts and nuts are out, the head gasket generally is somewhat stuck to the head and cylinder section. You'll need to persuade the head to unstick it, you can gently tap it with a soft hammer, sometimes a wedge is needed to unstick it. In either case make sure you are gentle with either one as the fins break easily and the wedge can easily damage the aluminum.
