Caliper grease?
77750
11
Japan
What type of caliper grease should I use when rebuilding caliper? I have the heavy black brake grease by CRC
No you dont put any lube on the piston other than a little brake fluid when it goes back together. If you put grease in there it will contaminate the system and start ruining seals.
I looked at the service manual and it shows you are correct. I was looking T the schematic of the caliper wrong. It does say to use a little silicone grease just on the pads only.
The back and sides of pads only
