Brake fluid capacity
You really just fill it up about 3/4 full, if you are working on the brakes and have just bled them you will need to add more after that process. Don't fill it all the way up because as you use them the levels will fluctuate. There is a line in some master cylinders that will show you but they don't all have them.
Consider what position the handlebars are in, some at 3/4 full may spill fluid on the tank paint (ruins it) if the bar is whacky enough in bend and you remove the cover at the wrong place.
