Bought a lemon deciding what to do with it.
canorthup
17
5
Minneapolis MN
I currently have a 79 CB750K, and I just bought an 81 CB750K for $300.00. It looked to be in great shape so I mainly bought it for the gas tank and side covers and figured the rest was just a cherry on top. The guy said he rode it all the time and it ran when parked it last year. I didnt beleive anything he said because the tabs are from 2014, it has 9k miles, and the plugs look new but the wires are completly gone, so I knew there was no way he was telling the truth, but anyway, when I got it home and looked it over it was acctually in to good of shape to just part it out. Except I tried to start it and it just clicked and nothing. I thought it wasa the starter so I removed the cover and pulled the sprocket and the starter worked great. Then since I had the cover off I tried to manually turn the motor over. it seems to be stuck in two spots. I pulled the valve cover off and as far as one can tell everything looked correct I think ( I could not see if the timing was off due to where it is stuck) But the timing chains feel like they have the correct tension. I scoped the pistons and didnt see any forign material.
After all of that should I just stick with the orginal plan and just part out the bike, wait for a motor to come up cheap, or take the motor out remove the top end and rebuild? I have not done a complete top end before, but it does not scare me, but I have other bikes and projects that I want to take care of as well.
Just wondering what other people would do in this situation. or if I am completely forgeting something to try.
Sticky in two spots makes me think it may have jumped timing and bent a couple valves. Is it difficult to turn over by hand with the spark plugs out? If it's only difficult in two spots with the spark plugs in, it could have lost compression on a couple cylinders...
If it bent valves by slamming them into the pistons, it'd need a lot more than just a top end. You'd have to split the cases open, make sure the connecting rods weren't bent, replace the pistons, probably replace the entire cylinder head...tons and tons of work and cost.
9,000 miles would be unusual for a motor to suffer a catastrophic failure, but not if it had a bad enough Previous Owner.
You own it....
Pull the motor & tear into it.
Check the valves first when you pull the heads.
You can buy a cheap fiber scope from harbor freight and stick it down the plug holes to look for hits on the top of the pistons.
You may not have to go all in.
After you pull the heads, roll it over and see if those stiff spots are gone.
On each piston, as it goes to TDC, make note of the distance in comparison to the cylinder top wall or measure it with a caliper.
If all four are the same then the chance of a bent rod is pretty slim.
So.... just dig in! It will be fun and you'll feel great once you've solved.
You own it....
That last sentence is the most expensive sentence in motorsports.
I tore the top end off my old Harley, just to replace the cylinder base gaskets. Two years and $5000 later I finally had the bike back on the road. :bike: :bike:
I hate to see a good looking complete bike get cut up or parted out. That being said its your bike, what makes you happy? Alot of these have been chopped and parted. I keep mine to enjoy the nostalgia. They ain't making any more and they are 40 plus years old now. Be interesting to see how you went and what you found. Good luck.
