So i have been working hard on getting my dirtball bike to run lately. (Keep in mind this bike started up fine last fall). I have replaced the stock carbs for the Murrays 4 to 2 mikunis, fixed my starter clutch issue with an r6 clutch, just put in fresh oil and filter, changed the plugs and checked for spark, fully charged the battery and put fresh fuel in the tank. Last fall i tried running the bike on pods and it would start fine, rev fine, but under load it only would rev up to 4k rpms (naturally because of no air box).
Now when i go to start it the bike cranks over fine without the grinding noise of a loose bolt on the starter clutch but she just wont fire (correction: it did actually fire once and the idle went up because i had turned the screws in too far and the chokes were on) backed the idle off a bit and tried again with zero luck. Also as it is cranking if i twiat the throttle at all the left side carb spits a harsh puff at me through the filter. (Literally everytime i twisted it) someone please help me before i break something or just sell the bike out of frustration. :-(
