95' NightHawk 750 need custom battery box
CodyNightHawk750
9
US
I need a battery box that will work on my 95' cb750, i bought a new battery and when i took the bike apart to install I realized the original box has been removed due to pod filters on the carbs, so i look down and the battery is literally hanging with zip ties inside the swing arm. Smdh Lol. So i need to build a box or buy one that will work for this bike.
Post links or pics please.
All help will be appreciated. Thanks
Hope the mounting points were not removed like so many do without thinking. Then get an OEM one as that model is not customized so much as butchered and where they all go. No custom part made, the market won't support it. I'd be looking closer too, the boxes generally serve double duty to mount other stuff too.
Free service manual here, it may show what the box looks like.........check out page 13-4.
https://moto-odejda.ru/file/HondaNithawk.pdf
Built my own box out of angle iron and flat stock, used 2 pieces of all thread and some lock nuts. Bent a piece of thin aluminum for a shield. Turned out nicely I believe. It bolts to the bottom of the frame and the original points where the airbox went.
If that aluminum shield is simply snapped into the box bottom and it gets loose to touch the positive post you'll have great fun and maybe even a fire.
I had put something else in there and then in consideration to you I removed it, not meant as such but sensitive people may take it as insult. Apparently it was a premonition. Great answer to my doing that. And I was concerned you might get a fire, good reply back.
I'll leave you alone.
