'94 SEVEN FIFTY NEUTRAL LIGHT WITH 1st GEAR
Txop
Spain
Hi everyone!
This is my first post. Thanks for admitting me into the group.
I have a '94 Seven Fifty. The neutral light also illuminates when engaging first gear (if forcing the gear lever it turns off). At all other gears it works properly and turns off.
Has anyone had the same problem? The sensor is not cheap at all and I wouldn't like to remove it but continue with the same fault...
Thanks in advance!
I had the same with my ‘96. In fact the neutral light would dim sometimes depending on the gear. Replacing the neutral sensor fixed it. I don’t remember it being expensive as I sourced mine from IMPEX Japan, I do remember though that the locating phillips head screws needed gentle persuasion from an impact driver after spraying them with oil to soak in first. Here is the price in USD, less freight of course.
