93 Nighthawk 750 needs valve job
Lucky30Eight
Farmington NM
Hey all, first time posting.
I have a 93 Nighthawk 750 with 20,500 miles that I noticed is low on power. It is also a little difficult to start (takes a small blip of throttle), and the idle can be uneven. No smoke from exhaust that I have noticed. I have owned the bike for a few years and it was running really well up until maybe a month ago. I cleaned and re-jetted the carburetors for correct air fuel mix at my elevation less than 1 year ago, and the spark plugs are a nice tan with no oil or carbon fouling. I checked the easy stuff, air filter, spark plugs, and coils already.
I just did a compression test and here are the results:
(Clymer manual states standard compression is 142-199psi)
Cylinder 1: 75psi -- Wet compression 65psi
Cylinder 2: 105psi
Cylinder 3: 110psi
Cylinder 4: 110psi
With Cylinder 1 being so low compression I tried a wet compression test and the psi dropped to 65psi. I am not that mechanically capable but I believe that means that it is likely not piston rings, but an issue with valves. I would also guess that the valve cover gasket needs replaced as well, since compression is low across the board.
I am unsure of what to do at this point. I have contacted all of the motorcycle mechanics in my area (Farmington NM) and no one is willing to work on the bike. My question is, does anyone know of a mechanic I could ship the engine to? Or should I attempt to do the work myself? I have never torn down an engine before and I am having a hard time finding the information on how to go about doing the work.
Any help is appreciated. Thanks
Valves could very well be the issue. You can do it yourself. Watch some YouTube vids to gain some familiarity with the process and tools (if applicable).
How are you doing the compression test?? Throttle wide open?? At 20,000 miles you should not have valve problems depending on how the bike was treated. Maybe a leak down test putting compressed air in the cylinder to check for leaks. Remember these bike have hydraulic lifters doing a compression test with no oil pressure will not let valves open completely
Throttle held wide open with a tester that screws into the spark plug hole.
I feel like 20k is very low to be having issues as well, but the previous owner definitely neglected the bike. I replaced the exhaust when I got it because the system was rusted out, and what I could see through the exhaust exit from the head was stark white, leading me to think it had run very hot and lean before I got it.
Doing a leakdown with compressed air is not something I am familiar with. Can you give me some instruction or link to something that does please?
20k is low for a valve job need, but it is even less for needing rings. One of your valves could be stuck. Could be from sitting or could be from a lack of oil and why the bike was laid up in the first place. Valves are easy to check. I would do that.
I hadn't considered a valve might be stuck. I believe I can simply remove the valve cover and check the valves from there correct? If a valve is stuck, would I be able to get it unstuck from there as well? Or would that require taking the head off of the block?
If you put air pressure into the spark plug holes you can hear if a valve is stuck open.
Seems you are interested in a tear down… have at it!!!
Then someone can buy your parts bike/ unfinished project.
From your first post:
I have a similar situation, but my compression went UP with wet compression test. Lowest cylinder was 60 dry/85 wet. Highest was 90 dry/ 110 wet. My valve gaps are all loose and the engine runs, but rough and smokes a bit from all cylinders. I bought this bike from a guy who basically kept it together with hot glue and beer tabs. But the mileage is unknown. I'm currently pulling the motor, but I want to MAKE SURE what the problem is before I start calling machine shops and ordering rings.
Welcome, Heathen. Please share pictures and procedures. I might learn sumptin'.
I actually just threw it back together enough to run the motor again. Someone pointed out that I may not have let the motor run long enough to actually let the rings expand. I killed it and did the compression test because it was smoking from all 4 pipes and i guess I've just convinced myself that the motor was trashed.
I'm glad I did start tearing it down because I found missing frame bolts and cotter pins replaced by nails and loose stator contacts. It was insane that this bike started at all.
I'm currently fighting an ignition issue where cylinders 1 and 4 aren't firing. Narrowed it down to a bad pulse generator. Hooray. A $400 part!
