82, 750, how do I mount the 2 ignition modules?
Donj
5
Indiana
Took it apart last Jan. Got the TS flasher and the rectifier, and the "wire connector block". But the 2 modules are just hanging?
This is in left panel in front if the tool box.
Any one out there that can send me a pic?
Please PM me at email. Bmwdon@gmail.com
Thanks. And the lesson of more more pictures has been learned
Don J
They mount back to back on a single screw going into .... I'm not sure, hope this photo helps.
Not quite the same as mine
Is that pic from '82 750 DOHC?
Similar, but diff from mine.
Mine has the tool box IMMEDIATELY behind, against the bracket that holds the elec connections. I have only 4 connectors, yours show 5.
I would send a pic of mine but am too challenged to do it
My "stuff attaches to studs on batt box, the rectifier mounts first, then on left stud, bracket with TS flasher and Red batt terminal mount. On rite, the bracket with the four connectors mounts. These 2 bracelets are a definite fit here.
Confused Don
FIGURED IT OUT!!!
They mount horizontally across the TOP of the batt box. There is a tab and they just "fit right in".
Thanks Dave for your response. It did wake me up to other possibilities
X2, was about to post they mount horizontal as well.
Need to detail the bike type --as in C, F, L, K, different bikes every one.
