'79 CB750F super sport / DOHC -- replacement rear brake master cylinder
Luis Etchenique
'79 CB750F Super Sport
71
24
South Ponte Vedra Beach, Florida
hello CB750 friends -
in the proces of resto-modifying ( into a race replica ) my CB750F s/s, like most of the bike ... the rear brake's master cylinder is completely gone -- I had to cut it off from the footpeg brackets, since it was welded by years of galvanic corrosion
so my question is: any recommendation ( s ) on a replacement unit ? ... so far, I have only found re-build kits, but not complete sets
the bike will see minor use and performance is not an issue -- I just want a functional unit
thank you as always for your repeated help !
Luis Etchenique
South Ponte Vedra Beach, Fla.
-USA-
Most of those generic ones should work however just check the centre to centre bolt distance against yours if you're not planning to modify the mounting point. I used the below on mine (82 CB750F) which looks very similar to the one you posted except for the bolt spacing distance.
https://www.ebay.com.au/itm/253937550061
