mrmach5
79 CB 750F , Soot black carbon fouled plugs after 20 minutes of running .Compression test all four range from 155-160 PSI. Adjusted the valves. Stock exhaust and factory air box. Complete carb (VB42A) rebuild , ultra sonic clean all new o rings, air cut off valves and accel pump. Used all factory brass parts 68 mid jet 102 main jet, Mixture screws 1 1/4 turns out. Confirmed choke blades fully open, Carb sync and dynamic timed. New plug wire caps. Denso
X22EP-U9 plugs.
I'm about out of ideas??
X22EP-U9 plugs.
