rcuttler
I have a '77 CB750K and after removing, cleaning and replacing the carbs I attached to throttle cables. It was a total bitch to do. I think the proper way is to attach the cables before fully installing the carb rack, which I did not do. With the carbs in place it took me at least an hour to attach the cables, and I'm pretty sure I screwed it up as the return to idle is very slow. The cables have been lubed and were free, so I think there is something binding at the connection to the carbs. Does anyone have a picture of the actual connection of the cable to carbs? Also, is there an easier way to install the cables while the carbs are already in place or do I actually need to detach the carbs again to install the cables? TIA
Bob
Bob
