76 CB750 Brake Upgrade
I just installed the all that stuff except the rotor and master cylinder yesterday(master will be here today). Parts all looked good and fit well. will finish and bleed today then test.
Has anyone used this system for a brake upgrade?
https://4into1.com/ultimate-perform...CzOJxLNgkGSbXuW-V-_dtna3QsGNPiCEpVtYQd1s_hVeo
Looks promising but who knows how well it's made.
Thanks
Jack
I'm using that master cylinder and left side caliper w/a dual front brake setup on my K4. I got my black coated stainless lines and fittings from them too, so same pieces. All works as expected.
My rotors are drilled OEM, and my right side caliper and adjusting screws are Yamiya.
Looking at that system, it's actually pretty good value for money.
But I'm recognising the same Chinese made parts available here in the UK.
From David Silver (UK), pattern brake caliper £119, pattern brake disc (undrilled) £125, pattern master cylinder £39, all plus the dread 20% VAT.
So with the brake lines, disc drilling, and other bits I reckon you're getting a bargain.
But it's a shame it doesn't contain a new arm and swinging pivot assembly.
AFAIK nobody is making pattern versions of these yet, and they're a frequent source of trouble when the pivot wears or seizes
