750k compared to 750c
no,not as a plug n play. i believe that they are different width motors so would it would take some fab work,then you will probably have hassles lining up the wheel and sprockets too.
a 79 750k frame and an 82 750c motor. and if the motor wont fit on, will i be able to take the cylinder jug from the 750c motor and put it on the 750k motor??
in my previous reply i assumed you were asking about swapping a750c dohc motor to a 750k sohc frame. my bad,,swapping a 82 motor to a 79 frame will most likely work since both are dohc motors.
