jamcamcb750
Hi all,
Relatively new to the group. I’ve got a 1975 Cb750 and it’s got a clutch problem that I’m looking to fix but wondering it if I can get some pointers on what the problem might be before I venture into fixing it.
The clutch pull is very light and all of the take-up happens right at the very end of the lever. I.e only about the first 10mm or lever pull is fully disengage/engage, the rest of the pull all the way back to the grip does nothing.
It’s annoying because In the action of changing gears quickly (normally) you always get a big rev of the engine because there’s a brief period when of throttle not fully shut off and clutch disengaged.
It’s not a cable adjustment issued as I’ve fiddled with both ends to no avail.
Likely to be springs? Worn plates?
Any help is appreciated
