71 cb 750 question
Jorgy
22
Sylvan lake
Does anyone know if the two coils on my 71 cb 750 can be rebuilt?
When I say that, I mean can the coil wires be replaced? Im aware the boot end comes off, but does the other
end of the lead twist off the coil?
Regards......
And true every last word of it.
Having said that I have taken a set off a 550 which are the same ones and carefully drilled and dremel ground into the plastic case to destroy the wire end attachment point to then pull the wires out of the casting and strung new plug wires in to reattach and then epoxied the holes back up. The coils ran fine and indeed running today after I did it back in 2003. Because the wires got old enough they started shorting through the insulation.
