The earlier cylinders didnt use the extra seals. Honda used the extra dowels and seals to try to stop the head gaskets from seeping oil because the stock cylinder studs stretch over time causing the head gasket to seep oil. If you look in between cylinders 1and 2 and 3 and 4 it is welded up if done properly. The 72mm cylinders are so big they break through the air gap when machined that large. If not welded up it will leak oil. Guys that do it the cheap way fill the gap with silicone instead of welding it. any questions about big bore motors feel free to ask
