1981 CB900C vent lines
mikemo
West Central Florida
Hello all, and thanks for welcoming me to the group. I'm working on a 1981 CB900C that belongs to a friend. It ran like crap and I offered to take a look, thinking some carb cleaning would get it back in shape. I quickly found #4 cylinder dead with almost no compression. It had a burned exhaust valve. So much for simple.
The bike has been apart for some time now as I waited to find a machinist who could work on the cylinder head. As I'm reassembling the engine to the frame, there are a few hoses that I can't figure out where they belong. I checked the service manual carefully but couldn't find the info there either. If anyone can help, it will be much appreciated.
This bike has a vacuum fuel shut off valve attached to the top of the carburetor bank. There are no details of it in the service manual I have . The vacuum line to the manifold, and the two fuel lines are clear, but there is another small vacuum-sized line that connects to the top of the diaphraghm housing. There is a hose connected to it, but I can't see where it is supposed to go.
Also, there is a large vent line coming out of the top of the transfer case (not the dual hoses coming from the crankcase). Again, it has a rather thick hose connected, but I can't see where it is supposed to go.
And the last, on the carburetor bank, there is a "T" fitting with a nipple between carbs 2 and three, toward the intake side of the carbs. It looks like it should have something plugged in there, but there was no hose connected.
Again, many thanks for any help you can provide. I REALLY want to get this bike back together and get my buddy back on the road.
Regards,
Mike M.
I asked the question of the tee between carbs 3 & 4 of the guy who rebuild my set as there was just an 8" length of rubber tube on it and he said it was simply a vent tube, I'm guessing for the air bleed system on the carbs.
It's the bowl vent. Air has to move in and out of the carburetor bowls because it gets displaced by fuel as the bowl levels go up and down in normal operation. If the holes were plugged, the bike wouldn't run because fuel wouldn't be able to flow in or out!
If it's a T-fitting nipple ONLY between carbs 2 and 3, right in the middle, then it's probably the fuel inlet hose. The vent tubes are between 1-2 and 3-4 and they are placed higher up than the fuel inlet, which is just above the fuel bowls.
These cylinder heads are old-school enough that you don't need a machinist to do valve work. You can put a new valve in that exhaust spot as long as the guide isn't worn out, and lap it to the seat yourself. It does require a valve spring tool and the seat has to be in good shape. It's not too hard to lap the valves in but it is tedious.
I would remove the vacuum shut off valve entirely. It's not necessary and the diaphragms fail with age and exposure to fuel. Just run a straight fuel line, ideally with a small inline filter, straight to the fuel inlet at the carburetors, and remember to turn the fuel on and off every time.
The vent line coming out of the transfer case would either go to the airbox if there's a nipple for it, or be completely open. It is probably just an air breather tube to allow warm air to vent out as the transfer case heats up and allow air back in as it cools off. If it wasn't present, the air inside would build up pressure and eventually pop out the seals and gaskets!
If you want to and the airbox doesn't have a place for it, you can get hold of a "breather filter" that fits the size of that line. All it does is put some kind of filtration material, often cotton or metal mesh, at the end of the hose. Keeps dirt out. I've done that on a few vent tubes in my own bikes. It can even be done to carb vent tubes if the filter offers enough air flow. On small scooter engines I have used chainsaw fuel filters for the job because they're cheap and have very coarse filtration media, enough to let air in and out freely but keep road dirt out of the carb bowl.
The fuel inlet is between carbs 1 and 2 and towards the rear of the carb bank.
The smaller tee between 2 and 3 is towards the front of the carb bank and is a vent NOT FUEL.
As I understand from this forum the valves on the DOHC engine are not able to the lapped in as they have a hard coating which is removed in the lapping process.
Please correct me someone if I'm misinformed, im still picking up knowledge on these engines myself.
If you're lapping with fine grinding compound, it removes so little material from the valve surface that it shouldn't hurt anything. The hardened coating on the valves is a few thousandths thick and a gentle lapping will cut into the material of the valve seat more than it cuts into the valve.
Shoot, it's been a long time since I saw the carb rack on my own 1980. You're right, the fuel inlet is off-center. It's in the middle between 2 and 3 on basically every other 4-cylinder carb rack ever made...Honda in the 80's made a lot of weird choices.
