Scott A
I had posted this bike once before to get ideas on what it may be worth and what I needed to do to get it running. In its non-running state then it didn't get much attention. Thanks for your thoughts! My father-in-law had it in storage for ~15 years. We didn't even know he had it. It is now up and running. It wasn't to difficult. Got the old gas out of the tank and flushed it. No rust. Bought a battery and cleaned the mouse nest, acorns, etc. out of the air filter box. Initially it was missing on 1 cylinder. Removed the 4 carbs and cleaned/made sure all the ports were open. Found several plugged. Good now. The front brake is not working. The brake fluid had turned to paste. Took the master cylinder apart and cleaned it up, but still not working. The smaller port may still be plugged and I suspect the brake line is too. I took the front brake caliper assembly apart and it was clean, no paste. The bike needs new tires due to cracking. Would also do the tubes. Due to high humidity the chrome is quite rusted, but shines up nicely with fine steel wool. I show this in a picture of the front wheel. The exhaust is not original, I do have the original header pipes. All gauges, blinkers, and lights work. I have the original owners manual and title, which is clear. A short video and some pictures should be attached if I did it right.
Photos
Photos
