1978 carbs
Rhino2131
23
Lake Elsinore, CA
Hello, I am building a 1978 cb 750. Next up for me is the carbs. I have 2 of the 4 float cap covers. One of them had a 1 on it and the other has a 3.4 on it. When getting the other two float covers do I need one of each that I already have? Just making sure they all face towards the center of the carb? Because I cannot find a float cover that says #2 on it. Thank you.
P.S. this is my first build, so if it is a no brainer please forgive me.
Rhino
Carb number 2 has an accelerator pump built in to it so it doesnt look like the others. The drains on the bowls should face outward. Number 1 is on the left as you sit on the bike.
So, as I look on the web, I see all these look the same…? I am not talking about the whole carburetor, just the float caps. The caps are pictured below. Can I use two #1s and two 3.4s?
Thanks again,
Rhino
If all else fails call up cyclexchange and see if they will sell you a bowl. Dont know if they will but I know they have a bunch of parts that they use for reconditioning.
3 and 4 are the same cap so can be used on either carb.
This is true, but try to put it in the orientation where the bowl drain screw is facing towards the outside of the bike. If you interchange them you won't have easy access to the drain screw for the bowl.
