1969 Throttle Cables...
hvills
23
Texas
HELLO...
Can one of the early CB750 experts out there confirm the differences between the early 1969 4into1 throttle cable part numbers 17910-300-010 and 17910-300-030. As I understand/guess the 17910-300-010 cables had a larger end nipple (5mm) on the carb side that locks into the throttle air slide versus the later 17910-300-030 cables which had a somewhat smaller end nipple. Yes? No? Maybe? Other than this... were there any other differences between the two cables??? Both cables were the same except for this difference. Yes? No? Maybe?
THANKS,
HARRY
Please disregard the below post...
HELLO...
THANKS,
HARRY
I already got clarification on the differences between the two cables.
Never noticed any 5 mm nipples. But a difference were the cables out of the 1 into 4 cables were opposite to one another for the outer carburetors and the middle ones on the original one. Given a more even pull on the block inside compared to the new ones where it was evident the outer carbs required more pulling power from 2 turns forcing the slide inside to kind of tilt! because the cables out were side by side.
Erling.
PS By the way where did you get clarification and not telling us here?
