Results 1 to 14 of 14
Thread: Airbox vs Pods
  1. #1
    CB750 New Member Usefie's Avatar
    Join Date
    May 2013
    Rochester NY
    Posts
    Airbox vs Pods
    Im so sick of my airbox being in the way and thinking of changing to pods on my 81 CB750K, bad idea??? any thoughts
  2. #2
    CB750 Addict Dave's Avatar
    Join Date
    Sep 2012
    Ca
    Posts
    384
    Be prepared to retune the carbs if you do.
    The stock rubber boots work as velocity stacks and the shared airbox helps the balance between carbs. My bike already had a custom airbox when I got it but I don't know where to get them.
    Click image for larger version.
  3. #3
    Moderator dirtdigger's Avatar
    Join Date
    Feb 2012
    Black Hawk SD
    Posts
    2,526
    Bad idea, you will never get it to run perfect unless you spend some money and take it to a place that can dyno tune the bike. Pods were a cheap fix for the old 750's but it doesn't work well at all on the dohc motors. Stick with the stock box.
  4. #4
    Join Date
    May 2013
    Rochester NY
    Posts
    I was afraid it would have been a bad idea, I will stick with the airbox. Thanks dave and dirtdigger for the heads up. I do love your airbox dave, I wish their was something out their to replace the black plastic one that I have.
  5. #5
    Join Date
    Sep 2012
    Ca
    Posts
    384
    Usefie, that'a not my airbox but it is exactly like it. I easily found and image on the net. It might be possible to find one still I just don't know where.
  6. #6
    Join Date
    May 2013
    Rochester NY
    Posts
    Thanks for the heads up dave, I will search around
  7. #7
    CB750 Member btfulmer's Avatar
    Join Date
    Aug 2012
    Navarre FL 23566
    Posts
    17
    I say go wit pods. The stock air box is restrictive to meet import standards. You do need to jet the carbs though, up 2 jet sizes to start. I sourced carbs from a 91 they don't have any vacuum lines, you have to get hold of some 30 degree silicon tubes for intake runners. But they run great on my DOHC motor
  8. #8
    K2750tracy K2750tracy's Avatar
    Join Date
    Feb 2012
    Hanover Pa
    Posts
    449
    could you post some pics of that set up. I would be interseted in this conversion, did you have to change throttle cables.
  9. #9
    Join Date
    Aug 2012
    Navarre FL 23566
    Posts
    17
    I didn't need to change cables, however, my controls came from a shadow steed. But they are standard two cable set up. The stock carbs are 30mm the later year carbs are 34mm jetted up 4 sizes.
  10. #10
    CB750 Enthusiast Field's Avatar
    Join Date
    Mar 2013
    Montana
    Posts
    32
    I've been told that if you swap on some Mikuni carberators then pods work great. The stock carbs hate them on DOHC. You have to re-jet but it still won't work right.
    Ideal...
    Mikuni carbs, pods.
    Aftermarket exhaust (4 into 2, the 4 into 1 is better for race)
    Polish the heads intake (to gain some torque, not ruin your low end like porting would do)
    Upgrade ignition (I want to try the HEI upgrade, looks great for the $)
  11. #11
    Here is a breadbox for the earlier carbs. You could possibly find boots and modify it to fit. I haven't seen these made in years though. Pods suck on inline fours. It's near impossible to balance and you will lose performance.
  12. #12
    CB750 Member ROCCITYCB's Avatar
    Join Date
    May 2013
    Rochester,NY
    Posts
    7
    It seems like this is an ongoing debate, comparing pods vs airbox.. im also curious about this as well, I have a 77F with pod filters and it does not run well at all.. some people are saying mikuni's with pods and 4-1 and it will run great, some are saying this motor only runs well with the stock carbs and stock air box... can we get some clarification on this?
  13. #13
    CB750 Member oldschoolcarbs's Avatar
    Join Date
    Jun 2013
    Santa Clara CA
    Posts
    5
    Quote Originally Posted by ROCCITYCB View Post
    Pods are an unwise idea for several reasons.
    For one, they allow more air through so it's a challenge to dial in a proper fuel/air ratio that'll work across the range. A tad lean is good for very low end---easier starting and more robust take-off---but lean up high and you're shortening the life of your engine, perhaps dramatically.
    Plus, they load up and so need to be removed periodically for cleaning---the downside here is that in doing so you generally drive very small debris particles deeper rather than out. When I used them I fabbed foam outer covers. What a pain in the butt that was. Eventually they migrated into the trash.
    This isn't to say that they're uniformly bad but only that care must be taken to ensure that you're not trading a marginally neater look for later disaster.
    OSC
    http://www.oldschoolcarbs.com
    "A lie will be halfway around the world before the truth has its shoes on." Mark Twain
  14. #14
    CB750 New Member dasyaboy's Avatar
    Join Date
    Jun 2013
    davis, ca
    Posts
    they work fine, i have pods with 115 jets 2 full turns out, still messing with it but it runs like a champ.
Similar Threads
  1. CB750 Four K Airbox
    By CB750k1977 in forum The CB750 Garage
    Last Post: 02-21-2013, 04:25 PM
  2. which carbs are better
    By Clint in forum The CB750 Garage
    Last Post: 01-31-2013, 04:49 PM
  3. need help with carbs
    By neilc in forum The SOHC Garage (1969-1978)
    Last Post: 01-09-2013, 06:21 PM
  4. Mounting the airbox on a '77 F 750
    By jackbeagle in forum The CB750 Garage
    Last Post: 12-19-2012, 09:25 AM
  5. Does my carbs tilt to much?
    By Stabler in forum Carburetors / Fuel
    Last Post: 05-31-2012, 08:21 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
