I use a simple "U" tube manometer to synch the carbs on both my bikes. I had 2 5x1mm screws beheaded and drilled 1mm. Use the copper washer and a lock nut to secure, some insulation tape around the adapters to ensure a seal. Cylinder #2 is the benchmark, synch #1 with #2, then synch #3 with #4, finally hook up to #1 and #4 to bring both left and right banks into harmony. You don't need to hook up to all 4.
Most folks find this difficult to understand so, the 4 carbs are not connected together #1 & #2 are connected together, #3 & #4 are connected together so you have to imagine the 4 carbs being separated into 2 separate banks. There are 3 adjusting screws, the left hand one synchronizes the 2 left hand side carbs, the right hand one synchronizes the 2 right hand carbs, the center one brings both left and right hand banks into synchronization. It is best to use 2 stroke oil just in case some gets sucked into the intake.
