Results 1 to 11 of 11
  1. #1
    CB750 Member cbratbobber's Avatar
    Join Date
    Feb 2021
    Indiana USA
    Posts
    10
    Need help with kick-start
    I'm new to the Honda CB750 family. I just got my first one. The guy tells me that I got it from that the kickstarter is just stuck. And when I try to turn over the motor manually by hand with a wrench the nut just spins. Almost like it's stripped. Is the kickstarter broken or is my entire engine locked up?
  2. #2
    Join Date
    Feb 2021
    Indiana USA
    Posts
    10
    Also by the way the bikes at for 7 years before I got it so I was told
  3. #3
    CB750 Guru amc49's Avatar
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    3,476
    If you are not turning what is behind the nut you are not turning the engine.
  4. #4
    Join Date
    Feb 2021
    Indiana USA
    Posts
    10
    So then that nut is stripped?
  5. #5
    Moderator dirtdigger's Avatar
    Join Date
    Feb 2012
    Black Hawk SD
    Posts
    3,054
    what nut are you trying to turn? does it turn over with the starter?
  6. #6
    Join Date
    Feb 2021
    Indiana USA
    Posts
    10
    The big nut that goes onto the little nut in front of the points plate.
  7. #7
    Join Date
    Feb 2021
    Indiana USA
    Posts
    10
    And the starter isn't on it.
  8. #8
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    3,476
    I for one would not be using that nut to turn engine, rather, use the alt rotor bolt on opposite side. That timing side nut can get loose and mess with your timing.
  9. #9
    Join Date
    Feb 2021
    Indiana USA
    Posts
    10
    So take the points plate off and use the nut behind it? And btw I did put some marvel mystery oil in the cylinders to try and free it if its just a frozen engine. If it is going to break loose is it ok to use the kickstart to get the engine to free up? My buddy says I shouldnt because I can break the kick-start. I didnt think that the kick-start would be flimsy enough to break from that pressure. What do you think?
  10. #10
    Join Date
    Feb 2012
    Black Hawk SD
    Posts
    3,054
    if the nut turns and not the engine then the indexing pin is probably sheared off on the back side of the timing advancer. There is no nut behind the points plate. Take the left cover off and use the bolt that holds the flywheel on. The kickstarter was not made to be used a lot on these motors. the kickstart was made to be a backup to the starter. The shafts can bend, twist or even break if too much force is used, was common on high compression big bore motors. The ratchet mechanism can also be damaged if abused. Use the flywheel bolt till you know the engine is free.
  11. #11
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    3,476
    Your MMO may not lossen anything if it is stuck bad enough, I've seen some where you break various engine parts before the engine comes unstuck, including the cylinder itself. That kiskstarter would break long before that; some are so stuck the motor is scrap. I've had to drive pistons out with a sledgehammer before.
Similar Threads
  1. Kick start question
    By cad1978 in forum The SOHC Garage (1969-1978)
    Last Post: 05-17-2018, 08:52 AM
  2. Kick start doesn't return.
    By Radioone in forum The CB750 Garage
    Last Post: 07-26-2017, 08:35 PM
  3. Kick start guidance
    By Raymonty in forum The SOHC Garage (1969-1978)
    Last Post: 07-05-2015, 04:21 PM
  4. Hard start, kick and kick
    By neilmrogers in forum The SOHC Garage (1969-1978)
    Last Post: 08-08-2013, 07:49 AM
  5. Kick Start Only?
    By newguy in forum The CB750 Garage
    Last Post: 01-29-2013, 07:49 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
