Tail lights on but no break light
I moved your post into the correct forum. Have you checked fuses? power to and out of the switches? Power to the bulb with the brake lever/pedal pulled? check the easy stuff first.
Thanks dirt, I realized I put it in the wrong one after the fact..anyway ya I checked all the wiring and found the ground to both bulbs was not working so connected then to 2 of the many extra grounds ..I did not check the power from the break to the bulb ..I'll do that tonight ..thanks for your reply
