what tires can i stuff under this thing?
dasgoff
northern va
looking to order tires to get the frame rolling after paint. sizes on it currently are 100/90/19 f and 130/80/18 rear. disc brake rear if it affects fitment. looking for a beefy look but im aware the rear may stay where they are at since it looks like any bigger and it will rub. thanks for any tips
I've put 120 on the front before, biggest I ever used on back was 130 but some are not the same size as others and that would likely apply to the next step up too, or 140. The 130 I used was almost same size as the 120 back that came off it. The 80 middle number affects that as well, the lower the number the shorter the sidewall to affect tire rollout circumference.
The 140 will fit for sure if used on a 16 inch wheel. Nighthawk used them.
