1981 Honda CB 750 K Foek rebuild.
keges335
120
18
New Wilmington Pa
So I decided to rebuild my own frt forks this time,. I installed Bushings, New Seals in Tube first. I tried to install Shaft into Tube and now won" t go in . Should I have installed Shaft into Tube first ,. Or do I just have to use a little more pressure,.? I have seen it done this way,.,.
I've done it before to no issue but if you roll the seal edge over it will pinch, lock up and damage. The difference in bushings there may be it, I had none there, solid tube. Bushing edge may be grabbing seal edge.
