Results 1 to 4 of 4
  1. #1
    CB750 New Member gdickins1225's Avatar
    Join Date
    Dec 2019
    Montgomery, TX
    Posts
    Turn Signal Problem 77 CB750F Supersport
    I am experiencing a problem with my turn signals.
    1. Is there a way the beeper can be disconnected?
    2. When I put the switch for Left or Right they will not osolate. It just beep but no signal. the signal trys to work but will not work. If you manually use the turn signal switch the lights work fine. It is only when you set the signal it will not work correctly. Wondering if the signal solenoid needs replacing.
    Need some suggestions.
    thanks
  2. #2
    CB750 Guru amc49's Avatar
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    3,008
    Maybe. The beeper is simply unplugged to stop it and what I did on my same year same circuit 550. The turns must have enough load to flash or they won't, like if someone has used LED bulbs. The flasher could be bad if normal bulbs.
  3. #3
    Join Date
    Dec 2019
    Montgomery, TX
    Posts
    The beeper is in the headlight assy correct? The bulbs are as far as I know regular bulbs. I will check out to be sure. I do know that the flasher works better when at high RPM but it still is not a constant flash. I can get the flasher pretty cheap, so may change it out. I will check connections also. I have had some issues with the rear light due to bad connection.
  4. #4
    Join Date
    Sep 2015
    Fort Worth TX.
    Posts
    3,008
    Yes.
    The turns MUST have excellent grounds to cycle properly. Front bulbs need to be IIRC 1157 and back 1134? Or 1034, been while.
    The flasher may use only 2 leads, one green ground is provided for older flasher types, most don't use that third wire you will find right around the flasher, leave it loose. Thinking a #551 flasher works but it's been a while.
Similar Threads
  1. Turn signal bolt,.,
    By keges335 in forum Electrical
    Last Post: 12-20-2019, 03:12 AM
  2. Turn signal issue
    By Skelee in forum Electrical
    Last Post: 08-13-2018, 12:19 PM
  3. Turn signal diodes
    By SeattleRod in forum Electrical
    Last Post: 02-15-2017, 11:07 PM
  4. Want: 1979-81 CB750F rear turn signal stay
    By Doug750f in forum The CB750 Garage
    Last Post: 01-18-2015, 12:08 PM
  5. Right front turn signal on
    By nighthawking in forum Electrical
    Last Post: 09-29-2013, 08:00 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
